Oct 23, 2022Guru - Experienced User
New - R7000P Firmware Version 1.3.3.154 Released
Security Fixes: 10/12/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
Enable IPv6 Auto if you cont...
PaulGo
Oct 25, 2022Luminary
In order to enable IPv6 with Verizon FiOS you need to use Auto Config which will give you a LAN IPv6 address. The WAN IPv6 address is not shown. If you try Auto Detect it will default to 6to 4 tunnel. I did notify Netgear about this but so far it has not been implemented. Perhaps as IPv6 becomes implemented over more of the area that Verizon serves Netgear will correct this.
PaulGo
Oct 27, 2022Luminary
A follow-up on using IPv6 with Verizon FiOS. It appears Auto Config is just a temporary solution only supplying IPv6 for a short period of time. The Netgear IPv6 page still shows a LAN IPv6 address but using an IPv6 test in my browser no longer shows an IPv6 address and the test fails. Currently the only stable solution for using IPv6 is using DD-WRT which with a 56 prefix gives both a WAN and LAN address. Has anyone has been able to get Verizon FiOS IPv6 to work with Netgear firmware?
- FURRYe38Oct 27, 2022Guru - Experienced User
- PaulGoOct 27, 2022Luminary
I sent an email to Netgear Customer Support and a PM to DarrenM about this issue. Thanks for the advice!
- FURRYe38Oct 30, 2022Guru - Experienced User
- PaulGoNov 13, 2022Luminary
So far no response from Netgear on the IPv6 issue using Verizon FiOS. They have so many products that consistently need firmware updates so I assume this issue is not a priority (and may never be).
- FURRYe38Nov 13, 2022Guru - Experienced User
Also takes time. Seen fixes not arrive for serval months. We can only give them the info.
