Apr 17, 2022Guru - Experienced User
New - R7900P/R7960P/R8000P Firmware Version 1.4.3.88 Released
Security Fixes: 04/13/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
Download Link:
R7900P:
Gipper4u
Apr 17, 2022Tutor
Thanks for the heads up. Just updated and removed my manual DNS entries. All good so far, Cheers!
GapJack27
Apr 18, 2022Tutor
I've been running the latest firmware version (88) that released last week and, after several days, I've yet to run into the DNS Probe issues I had with 84. The IPv6 change didn't really work for me when I tried, so I had no choice but to revert to a previous working version, so I'm glad this latest version seems to be working.
- Retired_MemberApr 19, 2022
Had the same problem on this firmware. 1st 5Ghz channel kept dropping. Updated to the latest Version 1.4.3.88 and the problem vanished. Both 5Ghz channels are solid, and have been overnight.
- FURRYe38Apr 20, 2022Guru - Experienced User
OK, just put my R79860P with v.88 loaded and factory reset and setup from scratch online connected to a CAX80 in modem mode. Traffic Meter enabled. Armor, Circle and QoS disabled.
Wired speeds are good:
Also onboard Speed Test app seems to be fixed working now:
Will also monitor for DNS issues. I'm using default ISP detected DNS addresses.
- PapaWoofApr 21, 2022Star
Everything was good for about 36 hours and then I started having connectivity drops. My one software I use for work keeps reporting no internet connection. I have to change to a different connection or repair. It's bizarre. I loaded the new .88 firmware and did a full factory reset and started fresh. Still having issues.
- FURRYe38Apr 21, 2022Guru - Experienced User
Are you wired or wireless connected when you see this?
