Apr 17, 2022Guru - Experienced User
New - R7900P/R7960P/R8000P Firmware Version 1.4.3.88 Released
Security Fixes: 04/13/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
Download Link:
R7900P:
Retired_Member
Apr 19, 2022Had the same problem on this firmware. 1st 5Ghz channel kept dropping. Updated to the latest Version 1.4.3.88 and the problem vanished. Both 5Ghz channels are solid, and have been overnight.
Apr 20, 2022Guru - Experienced User
OK, just put my R79860P with v.88 loaded and factory reset and setup from scratch online connected to a CAX80 in modem mode. Traffic Meter enabled. Armor, Circle and QoS disabled.
Wired speeds are good:
Also onboard Speed Test app seems to be fixed working now:
Will also monitor for DNS issues. I'm using default ISP detected DNS addresses.
