Apr 17, 2022Guru - Experienced User
New - R7900P/R7960P/R8000P Firmware Version 1.4.3.88 Released
Security Fixes: 04/13/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
Download Link:
R7900P:
Gipper4u
Apr 21, 2022Tutor
fwiw, My DNS errors came back so it's back to manually assigning them. Argggh.
jnguyen
Apr 24, 2022Star
Having the same issue on my r8000p from the latest firmware this month, I don’t know how other people got it to work
- jnguyenApr 24, 2022Star
can confirm, the latest update this month (V1.4.3.88_1.3.50 - 04/13/2022) and the previous update (V1.4.2.84_1.3.42 - 10/08/2021) give the dns issue. reverted back to V1.4.1.68_1.3.28 - 01/08/2021 as its the latest stable firmware. turned off auto update. the only reason i'm still using netgear products because its routers support multiple devices sharing the same ports allowing all devices to have an open nat type, also I can't seem to find a modem without the puma 6 chipset manufacturer issue. monopolies suck.
- FURRYe38Apr 24, 2022Guru - Experienced User
Try enabling IPv6 on the router...
