Apr 17, 2022Guru - Experienced User
New - R7900P/R7960P/R8000P Firmware Version 1.4.3.88 Released
Security Fixes: 04/13/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
Download Link:
R7900P:
Synthdan
May 04, 2022Guide
Starting with R7900P Firmware Version 1.4.2.84, released in 2021, the R7900P router developed a serious flaw where web browsers would fail to load pages the first time they were accessed. This problem occurred in Chrome, Edge, and every other browser, and users were forced to downgrade to Firmware 1.4.1.68 in order to continue to use their router. This is all documented in this forum post from 2021:
Recently, on April 12th, 2022, a new firmware update, 1.4.3.88, was released. My router automatically installed this update, losing all of my settings in the process. Unfortunately the new firmware has the exact same website issue, so I've once again had to revert to 1.4.2.84.
Actually, it's worse than that. There is a serious error in the old 1.4.2.84 version. If you disable the "Router Auto Firmware Update" option and hit apply, the router's interface software crashes, and the router has to be rebooted. The setting is not saved. This is why my router auto-updated to the latest firmware even though this was not ideal.
So, I had to install the latest firmware, configure it to not auto-update, then revert to the previous firmware, in order to get the router to not break itself by installing the unusable new updates.
Netgear, are you going to fix your firmware problem with the R7900P? This was an expensive router and I'm hopeful that you will fix this serious firmware flaw. The 1.4.2.84 firmware version continues to work perfectly, but the broken updates say they have "security fixes" and I would like my system to be as secure as possible.
Thank you,
Dan
GenxBear
May 18, 2022Initiate
I have had the same issue with my R7060p Router and it was driving me nuts! I finally downgraded to the old 1.4.2.84 version to fix the problem. This the last Netgear product I am buying. Last year I had a 24 port Netgear die on me that had a 2 year warranty and I had to pay around $25-$30 for them to ship me a replacement. In the past they would just ship the replacement w/no charge when it was under warranty. Their customer service had gone down hill fast.
- FURRYe38May 18, 2022Guru - Experienced User
If you try enabling IPv6 on the router this helps with DNS issues. I have same v.88 loaded on mine. IPv6 enabled and no DNS issues. As others reported as well in this thread.
- GenxBearMay 18, 2022Initiate
FURRYe38I will upgrade the firmware and enable IPV6 on the router and see what happens... Thanks!
- steveofsdMay 18, 2022Star
Can you imaging when your cell phone not working 100% after an auto firmware update? Online product review can make or break a business. I got my R8000P from Costco, and I didn't do my homework. If I did I would not buy Netgear. The clerk told me more than a few people started to returning their routers because they're not working right after firmware update. And then there're people like me looking at forum like this one to find solutions. Most people don't want to deal with problems, they just want plug and play. No one want to reset or mess with the settings to making it work as before firmware upgrade. I hope Netgear PR is looking at online reviews and forum to see what people are saying about their products, if they want to keep their jobs.
