Apr 17, 2022Guru - Experienced User
New - R7900P/R7960P/R8000P Firmware Version 1.4.3.88 Released
Security Fixes: 04/13/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
Download Link:
R7900P:
Gipper4u
Jun 01, 2022Tutor
Pretty much nailed it. If I had the time, I'd play with OpenWrt to see how it runs on NetGear.
grapony
Jun 03, 2022Aspirant
I have a R6700 and a R8000p, both had the firmware problem. I really hope this firmware bug isn't on purpose, if it is they should have a class action lawsuit filed on them. I lost the use of two routers. Anyway I went with another company's router, Starts with a "A". Problems fixed and couldn't be happier. I'll never buy another Netgear product.
- Jimsto2Jun 08, 2022Tutor
Same problem. Started about 6-8 weeks ago. Firmware is up-to-date, rebooted router. No joy. Nighthawk R7900P Firmware Version
V1.4.3.88_1.3.50 - FURRYe38Jun 08, 2022Guru - Experienced User
Did you try a factory reset and setup from scratch then enable IPv6?
Please enable IPv6 as well after you get to the home page after you walk thru the setup wizard.
- Jimsto2Jun 30, 2022Tutor
Ok folks, I finally got back to working tis issue. Before trying a full factory reset, I enabled IPv6, rebooted the router and the devices. That appears to have corrected the problem. I have not gotten a DNS error since. Thanks for the assistance. I'll update if it shows up again.
- FURRYe38Jun 30, 2022Guru - Experienced User
- fsusiJul 07, 2022Aspirant
All,
I have read several posts about DNS not resolving and am suffereing the same issue and it is now impeding my ability to work from home. I can tell you the following:
- I used a managed switch and wireshark to monitor the traffic between the R8000 router and my cable modem
- I also used a seperate wireshark to monitor traffic between my laptop to the R8000 router
- I can see my l laptop send a DNS request to the router and the router forwarding the request to the specificed DNS service on the public side of the network. I also note the UDP source port on the public DNS request so I can then match it to my laptop request given the NAT table changes this.
- I can see the DNS service send a valid response back to the R8000 router with a destination address of my public IP address and the approprate destination port with matches the port used for the routers DNS request.
So far, so good, everything is as expected. Now it gets wired:
- The R8000 sends my laptop a DNS response with a "REFUSED" response code. Note, the DNS response from the DNS service did not have a REFUSED response code and in fact has the resolved address in it.
- The R8000 also sends the DNS service an ICMP message "Destination Port Unreachable". Funny thing is it I can see it is the correct desination port.
Clearly, this is not the correct behavior. It has nothing to do with my ISP or anything else like it.
Also, when I filter the trace on the public-side for ICMP Desination Port Unreachable messages, I have a lot of them and they are all comming from the R8000 and they are all assocated with DNS server responses.
I have the traces if it helps. I would like to know when there will be software to fix this, what work arounds are available, and if there is an older firmware version the WILL WORK.
- FURRYe38Jul 07, 2022Guru - Experienced User
Try enabling IPv6 on the router while v.88 is loaded. - fsusiJul 08, 2022Aspirant
It is a Motorola MB8611 and I will try IPv6 this afternoon
- FURRYe38Jul 08, 2022Guru - Experienced User
- Jimsto2Aug 08, 2022Tutor
About a month after enabling IPv6 and no longer getting the DNS Probe error, I started getting multiple daily random internet connection drops, all devices. I plan to roll back the firmware to .68. There seems to be a bunch of problems with the latest software releases and Netgear shows no sign of acknowledgement or fixing them. I suspect at this point that they are just joining the software obsolescence club and purposely trying to annoy customers into buying new hardware with bug filled updates.
- FURRYe38Aug 08, 2022Guru - Experienced User
So how are you determining that "multiple daily random internet connection drops" is a router or FW issue?
Is the Internet LED on your router showing AMBER when this happens? How about the wifi LEDs?
Did you try and disable IPv6 to see if the behavior changed any?
What CAT# lan cable are you using between the ISP modem, router and wired devices? CAT6 is recommended.
Would need more information and troubleshooting before blaming the router or FW.
Charter/Spectrum Technicolor E31T2V1 / DOCSIS 3.1 eMTA
Determined internet drops by observing computers, phones, Roku, Amazon smart devices all having connection disruptions simultaneously throughout the day for the past 2+ weeks, 3-5 times per day. They self resolve within a minute or two. If I reboot the router they appear to occur less frequently for about a day, 1-3 times.
I am making assumptions, but I never had any connections problems until I installed the latest firmware.
I have not checked the internet LED during a drop, but I will next opportunity.
I have not disabled IPv6 since enabling it fixed the constant DNS probe errors.
Using the yellow CAT-5E cable that came with the router, R7900P Nighthawk X6S.
Speed Test using Nighthawk App on iPhone: 459Mb Down, 23.3Mb Up.
From Win10 using Brave browser over wireless from Speedtest.net: 16.82Mb down, 22.91Mb Up
Ran these speed tests about 2pm while both wife & I were working from the house.
I have not done a factory reset since these issues started. If I do, should I save the current configuration and reload it or key it all back in manually like from the box new? Does factory reset roll back the firmware to what it shipped with or just clear configurations?
I would make sure your modem and ISP services are not adding to this problem. Sometimes ISP services can be problematic. Ask the ISP to check there logs and signal up to the modem for any issues seen around the same time frame that you notice that you can't get services thru the router.
I have not checked the internet LED during a drop, but I will next opportunity. Please check this next time.
I have not disabled IPv6 since enabling it fixed the constant DNS probe errors. Might keep IPv6 enabled to help with DNS issues.
Using the yellow CAT-5E cable that came with the router, R7900P Nighthawk X6S. I recommend using CAT6 cabling between the modem and router and to your wired devices.
Ran these speed tests about 2pm while both wife & I were working from the house. What are speeds seen over a ethernet connection with a PC?
I have not done a factory reset since these issues started. If I do, should I save the current configuration and reload it or key it all back in manually like from the box new? Make a backup config first however after doing a reset, I recommend setting up from scratch initially and see how things go. I would avoid enabling Access Controls, Armor, Parental Controls, QoS and Traffic Meter. See how it goes using this configuration. If not, you can reload the saved backup from file later on.
Does factory reset roll back the firmware to what it shipped with or just clear configurations? NO. Just clears any user configurations is all.
Does the router feel extra warm to the touch or normally warm? Might put a laptop fan under the router for additional cooling.
- MrfatboyAug 19, 2022StarI just received and email that there was a new update (.88). I came here to see if problems. It seems I’m late to the party 🤣🤣🤣
I think I will stick to .68👍🤪 - michaelkenwardAug 20, 2022Guru - Experienced User
Mrfatboy wrote:
I just received and email that there was a new update (.88). I came here to see if problems.Wise move.
Always a good idea to wait for the dust to settle.
But do remember that you can roll back to older versions if you hit problems with new firmware.
- FURRYe38Aug 20, 2022Guru - Experienced User
Any progress on this?
Jimsto2Jimsto2 wrote:
Charter/Spectrum Technicolor E31T2V1 / DOCSIS 3.1 eMTADetermined internet drops by observing computers, phones, Roku, Amazon smart devices all having connection disruptions simultaneously throughout the day for the past 2+ weeks, 3-5 times per day. They self resolve within a minute or two. If I reboot the router they appear to occur less frequently for about a day, 1-3 times.
- Gipper4uAug 20, 2022TutorWe're expecting a resolution any year now...
