Apr 17, 2022Guru - Experienced User
New - R7900P/R7960P/R8000P Firmware Version 1.4.3.88 Released
Security Fixes: 04/13/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
Download Link:
R7900P:
wglotz
Jun 28, 2022Guide
I installed V1.4.3.88 firmware and as with V1.4.2.84 I am experiencing DNS errors on my Windows 10 PC. When I rolled back to V1.4.1.82 Hot Fix the problems went away.
DNS_PROBE_FINISHED_NXDOMAIN
Router: Netgear Nighthawk X6S AC4000 R8000P Router
Modem: Netgear CM500
ISP Provider: Comcast.net
Does anyone know how to fix this?
Thanks,
wglotz
Jun 28, 2022Guru - Experienced User
Enable IPv6 on the router. Set Auto Detect.
Reboot the router, modem and all devices.
Thanks,
wglotz
- wglotzJun 28, 2022Guide
This is what I get when enabling IPv6 on router...
Router's IPv6 Address On WAN
Not available
Router's IPv6 Address On LAN
Not available
Is this ok???
- FURRYe38Jun 28, 2022Guru - Experienced User
Yes.
Not available
Not available
Is this ok???
Ok, looks as if IPv6 is enabled.
I will post again in a few days and let you know the results.
Thanks for the quick replies,
wglotz
