Apr 17, 2022Guru - Experienced User
New - R7900P/R7960P/R8000P Firmware Version 1.4.3.88 Released
Security Fixes: 04/13/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
Download Link:
R7900P:
wglotz
Jun 28, 2022Guide
Ok, looks as if IPv6 is enabled.
I will post again in a few days and let you know the results.
Thanks for the quick replies,
wglotz
Jun 28, 2022Guru - Experienced User
- wglotzJun 28, 2022Guide
One thing strange that happened when I enabled IPv6 it disabled my guess network???
wglotz
Disabled my guest network.
I re-enabled the Guest network and a few minutes later my 2.4 and 5G networks stopped working.
Rebooted Modem and Router and it is back to normal for now...
wglotz
- UmairJun 28, 2022GuideMake sure your wifi networks are set to operate on different channels. IPv6 in general has no impact with IPv4 setup. Infact they both can work simultaneously. Unless, there’s a software/ firmware glitch that is preventing it.
Personally, I avoid having too many wifi as they create interference. I used two 5G network and one 2.4 G network.
I setup the one 5G with isolated subnet so that it doesn’t disrupt my other private network. And I offer it to selective guests.
