Apr 18, 2022Guru - Experienced User
New - R7900P/R7960P/R8000P Firmware Version 1.4.3.88 Released
Security Fixes: 04/13/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
Download Link:
R7900P:
Dark360
Jul 17, 2022Star
Ignore me, I had left our android phones on Static IP and DNS, reverting back to DHCP and it is working fine now
shadowsports
Jul 19, 2022Hero
Been watching this thread. I'll try 1.4.3.88 in 2 days. Will be refreshing if the DNS issues is finally resolved.
- FURRYe38Jul 19, 2022Guru - Experienced User
I recommend enabling IPv6 if DNS issues are seen.
- shadowsportsJul 20, 2022Hero
Greetings,
Its already on, for years. I've been testing each few FW releases since 1.4.1.68. All have exhibited the DNS error with or without reset, starting from scratch or having IPv6 enabled, etc. I'm WFH tomorrow and will try 1.4.3.88, then report back.
- FURRYe38Jul 20, 2022Guru - Experienced User
Seems to work for some, others maybe not so much. May depend on configuration or ISP configuration as well.
I know I ran my R7960P with v88 loaded and saw DNS issues. Enabled IPv6 and DNS issues did not re-appear.
