Oct 06, 2022Guru - Experienced User
New - R7900P/R7960P/R8000P Firmware Version 1.4.4.94 Released
Security Fixes: 10/06/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
NOTE: May have long awaited ...
jrod10133
Oct 08, 2022Tutor
unfortunately this firmware did not fix the issue Im having with refreshing the page on a browser
Oct 09, 2022Guru - Experienced User
What browser are you using? Try a different browser?
Be sure all browser caches are clear.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Which model router do you have?
Did you apply the FW and reboot the router or did you factory reset and setup from scratch?
Is this happening across all devices?
Did you reboot ALL Devices after the FW was load on the router?
- Retired_MemberOct 10, 2022
Hi,
I have the sames problems.- FURRYe38Oct 10, 2022Guru - Experienced User
What "sames problems" are you having?
What model router do you have?
More details are helpful.
Retired_Member wrote:
Hi,
I have the sames problems.- Retired_MemberOct 10, 2022
Hi,
my router is R8000P.After update to version 1.4.4.94 the web pages do not open at first time (dns).
The wireless connection lost and back.
It´s not possible add device in DHCP server.
Thanks
- jrod10133Oct 10, 2022Tutor
R8000P Nighthawk X6S AC4000
im been can having this issue with three firmware on all browsers on google Chrome,Firefox and edge
Firmware Version 1.4.3.88
Firmware Version 1.4.2.84the only firmware that is working is Firmware Version 1.4.1.68 this an Annoying situation Im been having this issue for over a year now and I'm really not comfortable being in an old firmware but I have no choice
How been can having this issue with three firmware <What issue?
NG is taking a look at this. So for now. Use what works best for you. All we can do for now.
Done.
I put IPV6 in Auto Config.
The problems were solved.
Thanks
