Oct 06, 2022Guru - Experienced User
New - R7900P/R7960P/R8000P Firmware Version 1.4.4.94 Released
Security Fixes: 10/06/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
NOTE: May have long awaited ...
Oct 09, 2022Guru - Experienced User
What browser are you using? Try a different browser?
Be sure all browser caches are clear.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Which model router do you have?
Did you apply the FW and reboot the router or did you factory reset and setup from scratch?
Is this happening across all devices?
Did you reboot ALL Devices after the FW was load on the router?
Retired_Member
Oct 10, 2022Hi,
I have the sames problems.
- FURRYe38Oct 10, 2022Guru - Experienced User
What "sames problems" are you having?
What model router do you have?
More details are helpful.
Retired_Member wrote:
Hi,
I have the sames problems.- Retired_MemberOct 10, 2022
Hi,
my router is R8000P.After update to version 1.4.4.94 the web pages do not open at first time (dns).
The wireless connection lost and back.
It´s not possible add device in DHCP server.
Thanks
Have you enabled IPv6 (Auto) on the router to help with DNS?
How do you have the wifi configured?
Hi,
Thanks
