Oct 06, 2022Guru - Experienced User
New - R7900P/R7960P/R8000P Firmware Version 1.4.4.94 Released
Security Fixes: 10/06/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
NOTE: May have long awaited ...
Retired_Member
Oct 10, 2022Hi,
I have the sames problems.
Oct 10, 2022Guru - Experienced User
What "sames problems" are you having?
What model router do you have?
More details are helpful.
Retired_Member wrote:
Hi,
- Retired_MemberOct 10, 2022
Hi,
my router is R8000P.After update to version 1.4.4.94 the web pages do not open at first time (dns).
The wireless connection lost and back.
It´s not possible add device in DHCP server.
Thanks
- FURRYe38Oct 10, 2022Guru - Experienced User
Have you enabled IPv6 (Auto) on the router to help with DNS?
How do you have the wifi configured?
Hi,
Thanks
The IPV6 is Auto select.
I dont acess to router with Edge or Firefox.
The wireless configuration work well in version V1.4.3.88_1.3.50.
I dont use Smart connect.
