Oct 06, 2022Guru - Experienced User
New - R7900P/R7960P/R8000P Firmware Version 1.4.4.94 Released
Security Fixes: 10/06/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
NOTE: May have long awaited ...
cybot
Oct 16, 2022Luminary
Also.. router autoupdate lists this version but fails to install. attempting to do a manual install results with the router saying the firmware is incorrect.
Oct 17, 2022Guru - Experienced User
Are you sure you downloaded the correct FW file for your model Router? There are 3 different models listed in this thread.
- cybotOct 17, 2022Luminary
Yes I Downloaded It Twice From The R8000p downloads Page. The Router Is Not Accepting The New Firmware, Even As A Manual Update.
Came Across This Post And Wondered If I Could Be Suffering From Same Issue
- FURRYe38Oct 17, 2022Guru - Experienced User
Possible. Can you try an manually update to v1.4.1.68?
- 222Graham222Oct 17, 2022Guide
Nighthawk R8000P
Firmware Version
V1.4.4.94_1.3.56
Will not allow me to reserve an IP address for my devices.
I have some configured already, but wanted a new one for my Roku that isn't showing the correct address.
I removed the one I had configured for 10.0.0.14 OK
I try to set a new one, I click on the correct device on the add screen, it then allows me to change the IP address to the one I require, when I click add I get the message Invalid MAC address.
The Mac address has no colons in the returned error message, I have rebooted multiple times tried it with no internet or anything else attached to the computer using the interface, I have no idea what's happening!Oh BTW I corrected the loss of assigned IP by flashing a backup version of the router, it is still not operating correctly.
HELP!
