Oct 06, 2022Guru - Experienced User
New - R7900P/R7960P/R8000P Firmware Version 1.4.4.94 Released
Security Fixes: 10/06/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
NOTE: May have long awaited ...
Oct 17, 2022Guru - Experienced User
Possible. Can you try an manually update to v1.4.1.68?
cybot
Oct 17, 2022Luminary
I0p-V1.4.4.94_.3Installing The Firmware Version You Suggested. Upgraded With Out ANy Issues. That's Not To Say That There Are No Issues With The Firmware ItSelf Though. Trying To Install The Firmware File R8000p-V1.4.4.94_1.3.56.chk still Results With A Message Saying The Firmware File Is Incorrect. It Also Still Will Not Auto Install Via The Update Button.
