Oct 06, 2022Guru - Experienced User
New - R7900P/R7960P/R8000P Firmware Version 1.4.4.94 Released
Security Fixes: 10/06/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
NOTE: May have long awaited ...
mlenahan
Nov 01, 2022Guide
I upgraded to 1.4.4.97 from 1.4.3.88 - it lasted 2 days, then I went back to 1.4.3.88. For me I found 2 things broken:
1) Under ADDRESS RESERVATION, unable to add/edit a devices because it kept saying "BAD MAC ADDRESS". There was no way to add/edit anything.
2) Under ATTACHED DEVICES, the CONNECTION TYPE information is mostly missing, just shows "-". For some devices it would display 2.4G Wireless, but not all.
I have a R7960P.
- FURRYe38Nov 01, 2022Guru - Experienced User
Users have already posted that there are problems with v.94 so keep v.68 for now. I saw this as well. I've already passed this onto NG.
Thank you.
- SilvexPhotoNov 01, 2022Aspirant
I have the Nighthawk R7960P with V1.4.4.94_1.3.56 and has been working pretty good. I have lots of devices attached to it about 40-50. I usually add them to the LAN Setup and assign an IP address to avoid conflicts. Lately it does not let me add new devices with the error message "Invalid MAC address. 2CAA8E6B596A". This message is displayed for existing devices I want to rename or new devices I want to add. Thinking that it might have run out of space. I removed two old entries. With no luck. Using the App at least it lets me rename devices, but the app does not have LAN Setup menu (or I don't know how to get it).
- FURRYe38Nov 02, 2022Guru - Experienced User
Thank you.
