Oct 06, 2022Guru - Experienced User
New - R7900P/R7960P/R8000P Firmware Version 1.4.4.94 Released
Security Fixes: 10/06/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
NOTE: May have long awaited ...
SilvexPhoto
Nov 02, 2022Aspirant
I have the Nighthawk R7960P with V1.4.4.94_1.3.56 and has been working pretty good. I have lots of devices attached to it about 40-50. I usually add them to the LAN Setup and assign an IP address to avoid conflicts. Lately it does not let me add new devices with the error message "Invalid MAC address. 2CAA8E6B596A". This message is displayed for existing devices I want to rename or new devices I want to add. Thinking that it might have run out of space. I removed two old entries. With no luck. Using the App at least it lets me rename devices, but the app does not have LAN Setup menu (or I don't know how to get it).
Nov 02, 2022Guru - Experienced User
Users have already posted that there are problems with v.94 so keep v.68 for now. I saw this as well. I've already passed this onto NG.
Thank you.
- SkyHopperNov 07, 2022Aspirant
After I upgraded my Nighthawk X6S (R7900P) which is in AP mode to Firmware 1.4.4.94, I'm not able to access the Web UI. The network 172.16.x.x/22 network of which the AP is given a DHCP address of 172.16.x.5. It appears to reset the TCP connection when using any of the standard browsers ie Safari, Chrome, and Firefox. You can ping 172.16.x.5. But you can't access the R7900P via IP address via browser.
I have reset the router to factory settings. It works in router mode. But the second you set to AP mode, you can't login to the Web UI. It appears to work. WiFi works fine in AP mode. You just can't log into the web console to manage it.
Please fix.
- FURRYe38Nov 09, 2022Guru - Experienced User
Setting both a Static or using Dynamic configuration, I'm able to access my R7960P web page in AP mode using MS Edge:
However, my IP network is on 192.168 IP address pool configuration.
- sgmidfNov 18, 2022Guide
Hello,
I have an R7960 running firmware V1.4.4.94_1.3.56. When I go to reserve an IP address it gives me an error "Invalid MAC address" and displays the correct MAC address without the colons between the pairs. This is new behavior and is a problem Has anyone encountered this?
Thanks
Invalid MAC address. xxxxxxxxxxx
