Oct 06, 2022Guru - Experienced User
New - R7900P/R7960P/R8000P Firmware Version 1.4.4.94 Released
Security Fixes: 10/06/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
NOTE: May have long awaited ...
Nov 09, 2022Guru - Experienced User
Setting both a Static or using Dynamic configuration, I'm able to access my R7960P web page in AP mode using MS Edge:
However, my IP network is on 192.168 IP address pool configuration.
sgmidf
Nov 18, 2022Guide
Hello,
I have an R7960 running firmware V1.4.4.94_1.3.56. When I go to reserve an IP address it gives me an error "Invalid MAC address" and displays the correct MAC address without the colons between the pairs. This is new behavior and is a problem Has anyone encountered this?
Thanks
| Invalid MAC address. xxxxxxxxxxx |
- FlyingTsJun 28, 2022Tutor
I have been operating some time now with IPV6 enabled and continue to avoid the DNS problems. But, there is a slight connection delay after Windows starts that wasn't present before. I assume some sort of resolution or address assignment is taking place.
- FURRYe38Jun 28, 2022Guru - Experienced User
What router model are you referring too?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Please give more details on "slight connection delay after Windows starts that wasn't present before". What exactly are you experiencing?
Does this happen if you disable IPv6?
This happen on on devices?
- FURRYe38Nov 18, 2022Guru - Experienced User
This is a known issue.
- Dfox5Nov 19, 2022Tutor
I updated my 8000p router to Firmware Version V1.4.4.94_1.3.56 and was adding a computer to my LAN...it displayed in the list to add on the router so I just selected it but when I clicked ADD, it replied Bad Hardware Address and would not add it...the computer is connected by ethernet and can use the internet but I can't add it to my LAN so it will always have the same IP.
I went to another computer and tried to add it and same problem....I downloaded the previous firmware version R8000P-V1.4.3.88_1.3.50 and had no problem adding it my LAN...I think the new firmware is formatting the hardware address wrong by leaving out the colons and causing the bad hardware address problem.
I went through the process again...updated to latest firmware and then deleted a pc from the LAN...tried to add it back and it gives the message Invalid MAC address...load the previous firmware and can add it back to LAN with no problem...It has the colons in the address where it's listed but when adding it to the LAN and get the Invalid MAC address message, the colons are missing from that address.
The newest version does have a bug and will have to be fixed.
- FURRYe38Nov 21, 2022Guru - Experienced User
This is a known issue. Bug was reported and passed to NG for review already.
- FlyingTsNov 25, 2022Tutor
It was V1.4.3.88_1.3.50 on R7900P. The solution worked well for a long time but I am again experiencing problems. The version in place today is V1.4.4.98_1.3.56. I don't know yet when it was installed. Since my original fix and confirmation, I am sure Windows updates were installed and we experienced several power outages. It looks like I am starting over.
Comcast with owned Netgear CM400 modem.
Oops. Typo. 1.4.4.94_1.3.56
- LynthelDec 06, 2022Initiate
I am having a problem reserving an IP address for a specific device - my server. It keeps telling me the MAC address is not valid. I am attempting to assign an address outside of the range of devices on my network - 192.168.1.100. My other devices stop at 192.168.1.64. The reason I am trying to reserve this address for the client is because my router randomly changes the IPs including for this client. It is running VMs and apps that require a static IP address.
Steps I have taken:
I have verified the MAC address on MoBo box and in IPCONFIG.
Manually assigned IP, Subnet, Gateway, and DNS in Network/Network Connections/My Adaptor/IPv4 properties on the client.
Logged into my Router from a different client and can verify the server is connected using the IP 192.168.1.100.
Went to Advanced/LAN Setup and tried to add an IP address to reserve. I click on +Add. I select the server from the list that populates. It auto populates the form with the CORRECT MAC address. However, when I click +Add to add the IP address, I get and Invalid MAC address failure.
Please see attached screenshots.
Any help on this would be greatly appreciated.
- FURRYe38Dec 06, 2022Guru - Experienced User
Steps I have taken:
Having the same problem...no luck fixing it.
