Oct 06, 2022Guru - Experienced User
New - R7900P/R7960P/R8000P Firmware Version 1.4.4.94 Released
Security Fixes: 10/06/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
NOTE: May have long awaited ...
DexterJB
Oct 26, 2022NETGEAR Moderator
Hi RalfyM, if you're still experiencing the issues, you may try resetting the device back to factory defaults and setting it up from scratch. Let us know if the issue will persist.
Dexter
NETGEAR Team
222Graham222
Dec 21, 2022Guide
It's Netgear, they've screwed up the update; downgrading to the last version and everything is working OK now.
Very annoying when your routers programmers make a complete hash of everything!
- FURRYe38Dec 21, 2022Guru - Experienced User
There some beta that fixes this.
- ACMilan1899Dec 21, 2022Guide
Where is this “beta”?
can you share it?
Which model router do you have?
There is only a beta for the R7960P and R8000P models...
can you share it?
- ACMilan1899Dec 22, 2022GuideI have the R7960P with firmware v1.4.4.94 running on it.
- FURRYe38Dec 22, 2022Guru - Experienced User
thank you FURRYe38 … I will give it a try later today.
- clawnetDec 22, 2022Tutor
I would like to try the beta as well.
- FURRYe38Dec 24, 2022Guru - Experienced User
Sent.
Merry Christmas
- clawnetDec 25, 2022Tutor
Were you able to apply the firmware beta and did it resolve the invaid MAC address problem?
- Dark360Dec 25, 2022Star
I have been using the beta firmware for a few days now and it works fine.
MAC Address Reservation Issue Is Fixed
- ACMilan1899Dec 25, 2022GuideI can also confirm that the beta firmware has been working fine since I installed it on my R7960P router.
Merry Christmas everyone! - mlenahanDec 25, 2022GuideI too would be interested in the Beta firmware. Did the beta firmware also fix the incorrect connection listing in the connected devices screen?
- mlenahanDec 25, 2022GuideOops sorry about that, distracted by Christmas. I have a model R7960P.
- _-stu-_Dec 27, 2022AspirantGood to read that the beta is working out for folks! That said, I’m rocking an R8000P and I’d like to get in on some of this sweet beta action for myself.
Thanks Much! - ACMilan1899Dec 28, 2022GuideHi guys, so I have been testing the beta for several days on my R7960P router now and all looks fine… I just noticed that my latency increased from ~20 ms to 60 ms after this update which is not noticeable when browsing the Internet but when playing online games.
Has anyone experienced the same?
I know this is a beta version I am using but are there any tweaks I can perform on the router to get it down?
Other than that I don’t see any issues.
Thanks. - joealmonteDec 28, 2022AspirantI would like to test the beta firmware. Will you please provide the link to it.
- FURRYe38Dec 28, 2022Guru - Experienced User
What model router do you have?
joealmonte wrote:
I would like to test the beta firmware. Will you please provide the link to it. - Dark360Dec 28, 2022Star
What did you use to determine that?
Gotta cha.
