Oct 06, 2022Guru - Experienced User
New - R7900P/R7960P/R8000P Firmware Version 1.4.4.94 Released
Security Fixes: 10/06/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
NOTE: May have long awaited ...
ACMilan1899
Dec 25, 2022Guide
I can also confirm that the beta firmware has been working fine since I installed it on my R7960P router.
Merry Christmas everyone!
ACMilan1899
Dec 28, 2022Guide
Hi guys, so I have been testing the beta for several days on my R7960P router now and all looks fine… I just noticed that my latency increased from ~20 ms to 60 ms after this update which is not noticeable when browsing the Internet but when playing online games.
Has anyone experienced the same?
I know this is a beta version I am using but are there any tweaks I can perform on the router to get it down?
Other than that I don’t see any issues.
Thanks.
Thanks.
- joealmonteDec 28, 2022AspirantI would like to test the beta firmware. Will you please provide the link to it.
- FURRYe38Dec 28, 2022Guru - Experienced User
What model router do you have?
joealmonte wrote:
I would like to test the beta firmware. Will you please provide the link to it. - Dark360Dec 28, 2022Star
What did you use to determine that?
Gotta cha.
- ACMilan1899Dec 28, 2022GuideI compared the 2 firmwares and default settings except Wi-Fi setup.
Both times I reset the router and setup from scratch.
I used 1.4.1.68 - latency ~20 ms
Beta 1.4.4.95 - latency ~60 ms
Also used this website to determine bufferbloat: https://www.waveform.com/tools/bufferbloat - joealmonteDec 29, 2022Aspirant
FURRYe38, I would like to test the beta firmware for the R8000P.
