Oct 06, 2022Guru - Experienced User
New - R7900P/R7960P/R8000P Firmware Version 1.4.4.94 Released
Security Fixes: 10/06/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
NOTE: May have long awaited ...
krychak
Jan 06, 2023Aspirant
I am also having this issue. R7900P. I've been waiting for an update from Netgear for months but maybe they don't support it anymore? Any help would be appreciated.
Thanks
- FURRYe38Jan 06, 2023Guru - Experienced User
I presume since the 7900 series hit EoL, I doubt NG will be forth coming with any fixes for these models:
https://www.netgear.com/about/eos/
Best suggestions would be to downgrade to prior working version of FW.
Find some 3rd party FW that you can use, i.e. OpenWRT or DD-WRT.
Punt and get you something new.
Thanks
- krychakJan 06, 2023Aspirant
Thanks. Softpedia had older versions I was able to install. 1.4.3.88_1.3.50 worked.
NG also still carries prior versions of FW as well:
https://www.netgear.com/support/product/R7900P.aspx#download
