Oct 06, 2022Guru - Experienced User
New - R7900P/R7960P/R8000P Firmware Version 1.4.4.94 Released
Security Fixes: 10/06/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
NOTE: May have long awaited ...
krychak
Jan 06, 2023Aspirant
I am also having this issue. R7900P. I've been waiting for an update from Netgear for months but maybe they don't support it anymore? Any help would be appreciated.
Thanks
Jan 06, 2023Guru - Experienced User
I presume since the 7900 series hit EoL, I doubt NG will be forth coming with any fixes for these models:
https://www.netgear.com/about/eos/
Best suggestions would be to downgrade to prior working version of FW.
Find some 3rd party FW that you can use, i.e. OpenWRT or DD-WRT.
Punt and get you something new.
Thanks
- krychakJan 06, 2023Aspirant
Thanks. Softpedia had older versions I was able to install. 1.4.3.88_1.3.50 worked.
- FURRYe38Jan 06, 2023Guru - Experienced User
NG also still carries prior versions of FW as well:
https://www.netgear.com/support/product/R7900P.aspx#download
- DavidNC78Jan 08, 2023Tutor
Can I get this Beta Firmware as well to fix my LAN MAC address issue? I've got the R8000P and my current firmware is 1.4.4.94_1.3.56 and I am on Windows 11. Also, since this Beta Firmware has been used for a few months now has anyone ran into any issues with it, besides the slightly added latency thing?
Thank you.
