Oct 06, 2022Guru - Experienced User
New - R7900P/R7960P/R8000P Firmware Version 1.4.4.94 Released
Security Fixes: 10/06/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
NOTE: May have long awaited ...
Dec 25, 2022Guru - Experienced User
What model router do you have?
mlenahan wrote:
I too would be interested in the Beta firmware. Did the beta firmware also fix the incorrect connection listing in the connected devices screen?
mlenahan
Jan 09, 2023Guide
I've been using the beta 1.4.4.95 firmware for a couple of weeks now on my R7960P. That fixed the MAC address issue and the missing/incorrect connection information. However I've discovered two issues:
A) Traffic meter does not work correctly. There is nothing displayed for yesterday (zeros), and this week & this month are always the same numbers as today. Last months numbers seem to be correct (maybe), but hard to know.
B) Email notification incorrect. I have to set to email me the logs weekly Sunday @ 00:00 and what I get in the email is valid data (log info) for the day before (Saturday). The rest of the text in the email is hundreds of lines of "Wednesday, Dec 31,1969 16:00:00"
Thanks for the support.
- DavidNC78Jan 12, 2023Tutor
Can someone send me this firmware then that fixed the issue so I can load it?
- DavidNC78Jan 19, 2023Tutor2023-01-13 09:20 AM
What model # router do you have?
- johnscrubJan 21, 2023Aspirant
would it be possible to get this beta firmware for a 7960p?
- mlenahanJan 22, 2023Guide
Another update - On my R7960P using the 1.4.4.95 firmware, in ADVANCED HOME -> SHOW STATISTICS, there's actually a few issues.
- WAN port line shows zero for TX B/S, RX B/S (however LAN ports show non-zero TX B/S, RX B/S)
- All 3 radio lines show zeros for TXPKTS, TX B/S, RX B/S
Additionally the COLLISIONS column is all zeros, which is normally what it should be, however given other fields are zero, this should be reviewed because maybe it's just not reporting collisions.
Thanks,
Mike
