Oct 06, 2022Guru - Experienced User
New - R7900P/R7960P/R8000P Firmware Version 1.4.4.94 Released
Security Fixes: 10/06/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
NOTE: May have long awaited ...
Retired_Member
Jan 26, 2023Hi I’m looking for the new beta fw for the R7760P. Does this firmware fix the dns probing issue? I’m currently on 1.4.1.68 as it’s the only one that doesn’t have this issue.
Jan 26, 2023Guru - Experienced User
Please re-confirm your router model # please.
- tchesketJan 26, 2023Aspirant
Hello,
I have a Nighthawk R7900P, having the same "invalid MAC address" issue when trying to reserve addresses. I have it on V1.4.4.94_1.3.56. Can I also have a link for the new firmware that fixes this issue please?
Thanks- FURRYe38Jan 27, 2023Guru - Experienced User
You'll need to load a prior working version of FW for your 7900 series. NG did not produce a beta for the 7900 series since it went EoL:
tchesket wrote:
Hello,
Thanks
- Retired_MemberJan 26, 2023Yes my mistake it’s the R7960P.
