Oct 06, 2022Guru - Experienced User
New - R7900P/R7960P/R8000P Firmware Version 1.4.4.94 Released
Security Fixes: 10/06/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
NOTE: May have long awaited ...
Raptorialand
Mar 05, 2023Aspirant
I updated my firmware now nothing works...
Steam does not load (have to reload it 5 times)... and every new site i open has a dns error.
I know this issue already after fighting with it and solved it with 6to4 tunel.
I am an absolute noob and i dont know what i am doing with all this settings... i dont know what they mean and i dont know what they do.
i bought an expansive router and now i have to infest my freaking freetime to understand all that bs!
Also why just upload the beta in the download section. NO you have to login.
I tried my password 4 times... slowly ... did not work... reset the password... type in new password (ohhh password is old try a new one)
Is anything working with this company.
Please just send me the beta or tell me if the update will be released in the next weeks so i dont have to learn how to manually install a firmware (and prob. learn how to roll back to an old firmware because nothing netgear is releasing works)
sry 4 being so angry but i really have enough of it now.
(i also used a pihole - yeah only follewed youtubetutorials and installed it somehow and get it to work... it worked well until i first updated the firmware of the router. because i am a noob i thought it is an issue with pihole. so i wasted weeks without thinking about the router... later i found out it was of course the routerfirmwareupdate. solved it - as already told - with 4to6 tunel option.
Oh god i wasted so much time on this already... just give me something that works. Its 2023 - all i want is freaking working internet on my Windows pc (Every other android tablet, phone, mac, ... works!)
Thank you
Mar 05, 2023Guru - Experienced User
What model router do you have?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
Iv'e switched to 6rd for any IPv6 tunneling configurations. I use Hurricane Electric.
- RaptorialandMar 05, 2023AspirantRouter: R8000P
Modem: Arris TG2492S
Cable cant be the issue if it worked 3 days ago?
No i did not do that - does it delete all the settings if i make a factory reset?
Where can i find that? Do you mean dhcp = dns server? Its set to pihole of course.
192.168.x.xx
Thank you- FURRYe38Mar 05, 2023Guru - Experienced User
If your running PiHole has a DHCP service, did you disable DHCP server on the NH router?
Yes.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-modeI believe the Arris supports option #1...
- RaptorialandMar 05, 2023AspirantThank you
The modem is just passing the signal to the nighthawk ... thats the first thing i did while setting up arris.
Called my provider and let them do this
