Oct 06, 2022Guru - Experienced User
New - R7900P/R7960P/R8000P Firmware Version 1.4.4.94 Released
Security Fixes: 10/06/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
NOTE: May have long awaited ...
SkyHopper
May 22, 2023Aspirant
I just upgraded to 1.4.4.94 on an R7900P when it was in Access Point mode and now I cannot log into the admin console via web. If I reset to factory settings and returns to router mode, I can login to the admin console. But If I change to access point mode from router mode, it fails to login again. When I use Chrome to access the admin console, it returns with an error "empty response." When I use curl it gives an "curl: (52) Empty reply from server" error.
If I downgrade the R7900P to a previous firmware release such as 1.4.1.42. It works fine again. But I don't like staying that far back on security fixes. I'm back on 1.4.4.94 and can't login to the admin console again, but it seems to retain the wireless configs and it's still working as an access point but can't login to the admin a console.
This is a reproducible problem.
Please fix this. This is a major problem as I use an Orbi RBRE960 for my main network and an R7900P for my IoT network. The RBRE960 IoT network is super slow. So I use the R7900P for IoT instead. I set the DHCP address of the R7900P from the Orbi RBRE960. And, I'm able to ping it.
if I use openssl s_client, I'm able to see the self signed certificate
Issuer: C=US, ST=California, L=San Jose, O=Netgear, CN=www.routerlogin.net/[email protected]
Validity
Not Before: Aug 23 11:54:06 2022 GMT
Not After : Aug 20 11:54:06 2032 GMT
Subject: C=US, ST=California, L=San Jose, O=Netgear, CN=www.routerlogin.net/[email protected]
X509v3 extensions:
X509v3 Key Usage:
Key Encipherment, Data Encipherment
X509v3 Extended Key Usage:
TLS Web Server Authentication
X509v3 Subject Alternative Name:
DNS:www.routerlogin.net, DNS:routerlogin.net, DNS:www.orbilogin.com, DNS:orbilogin.net, DNS:routerlogin.com, DNS:orbilogin.com, DNS:www.routerlogin.com, DNS:www.orbilogin.net
Please fix this issue when in Access Point Mode.
- FURRYe38May 23, 2023Guru - Experienced User
Does this also happen in different browsers, Try MS Edge, FireFox or Opera?
FYI:
Might search for 3rd party FW solutions for your model router.
