Oct 06, 2022Guru - Experienced User
New - R7900P/R7960P/R8000P Firmware Version 1.4.4.94 Released
Security Fixes: 10/06/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
NOTE: May have long awaited ...
Aug 30, 2023Guru - Experienced User
Don't know. Will ask about it.
Phycodes
Nov 17, 2023Aspirant
Can I get the beta? On a R7900P
- FURRYe38Nov 18, 2023Guru - Experienced User
Unfortunately NG didn't put forth a beta for the R7900P since it went EoL service. Only thing that you can do is to revert back to an older version of FW that works or find some 3rd party FW like DD-WRT or OpenWRT FW to put on the R7900P.
Good Luck.
- michaelkenwardNov 18, 2023Guru - Experienced User
Good Luck.
Remember, there can be a big difference between the R7900 and the R7900P, the one you say you own. These variants can have completely different chips inside.
Whatever you do, do not try to install P firmware on the other version, and vice versa. You could end up with a dead router.
- PhycodesDec 22, 2023Aspirant
Looks like DD-WRT doesn't support it and OpenWRT only supports the R7900, not my R7900P which another user said cannot be interchanged.
How is the R7900 not EoL if R7900P is? Does that mean there will be no more firmware updates for me at all?
- FURRYe38Dec 22, 2023Guru - Experienced User
Both are.
Correct.
