Oct 06, 2022Guru - Experienced User
New - R7900P/R7960P/R8000P Firmware Version 1.4.4.94 Released
Security Fixes: 10/06/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
NOTE: May have long awaited ...
ACMilan1899
Nov 21, 2023Guide
What version is the beta for the R7960p?
Can you share a link to it?
Others with the R8000 router have an alternative to the Netgear firmware, they can use DD-WRT as the router is compatible… unfortunately myself by having the R7960p cannot flash the custom firmware… 😞
- RahulMNov 24, 2023Aspirant
Any update after this for R8000P. V1.4.4.95_22.10.25
- michaelkenwardNov 24, 2023Guru - Experienced User
For officially released updates, visit the support pages:
Support | NETGEAR
Feed in your model number and that page will have any software, firmware and drivers for your device.There is also a library of past releases.
Now things are fishy here. Why do u guys have problem in acknowledging version of BETA which you are giving it in DM?
