Apr 01, 2022Guru - Experienced User
New - R8000 Firmware Version 1.0.4.84 Released
Security Fixes: 3/30/22
Fixes security vulnerabilities. (Don't know if this resolves the DNS issues seen on v.76 version.)
For more information about security vulnerabilities, visit https://www.n...
fursty
Apr 01, 2022Initiate
X6 R8000 V1.0.4.84_10.1.84 MASSIVE SPEED DROP
Since update ... massive speed drop?
You didn't give us much to go off other than router and firmware.
What gateway is it connected to?
What drop in speed? (actual values)
Was it wifi? Wired? And if wifi, are you testing 2.4ghz or 5ghz? (hint, 2.4ghz is a much slower network)
If it was after a firmware upgrade, did you try a factory reset/reinstall?
- FURRYe38Apr 01, 2022Guru - Experienced User
Be sure your not using Armor, Circle or QoS when testing speeds...
