Apr 01, 2022Guru - Experienced User
New - R8000 Firmware Version 1.0.4.84 Released
Security Fixes: 3/30/22
Fixes security vulnerabilities. (Don't know if this resolves the DNS issues seen on v.76 version.)
For more information about security vulnerabilities, visit https://www.n...
uksu
Apr 08, 2022Tutor
So, after like 8 months and even releasing new firmware, the part with the remote management page where you can activate/deactivate remote control and use your own port is still not fixed as well as the DNS problem described here?
It is marked solved... How can you see this as solved? Nothing has been fixed but thankfully we have a workaround at least. But this is a core feature not to have to change adapter settings on EACH device... Come one, please fix this immediately.
How can NETGEAR release new firmware but not address these key features of a product?
Apr 08, 2022Guru - Experienced User
The remote management for web based remote access has gone away. Not coming back.
For some remote access and some remote configurations:
You'll need to downgrade FW to v.68 or v.62 until NG fixes the DNS issues.
