Apr 01, 2022Guru - Experienced User
New - R8000 Firmware Version 1.0.4.84 Released
Security Fixes: 3/30/22
Fixes security vulnerabilities. (Don't know if this resolves the DNS issues seen on v.76 version.)
For more information about security vulnerabilities, visit https://www.n...
Trevsweb
Jun 03, 2022Tutor
firmware: V1.0.4.84_10.1.84
Model: NighthawkNighthawk X6 R8000
Device reset to factory settings.
getting this page cannot be displayed on initial page load on multiple devices but then the page loads
also huge speed drops from 250mb/s to around 50mb/s
not expecting a fix but just highlighting so netgear can see the issue and try to patch the firmware
- FURRYe38Jun 03, 2022Guru - Experienced User
Try enabling IPv6.
Try a factory reset and setup from scratch. Be sure to not enable Traffic Meter as well.
- TrevswebJun 10, 2022Tutor
sorry mentioned in my previous post the router was reset to factory settings..
traffic monitor is off. still same issue
- FURRYe38Jun 10, 2022Guru - Experienced User
Try enabling IPv6.
