Apr 01, 2022Guru - Experienced User
New - R8000 Firmware Version 1.0.4.84 Released
Security Fixes: 3/30/22
Fixes security vulnerabilities. (Don't know if this resolves the DNS issues seen on v.76 version.)
For more information about security vulnerabilities, visit https://www.n...
Trevsweb
Jun 11, 2022Tutor
Virgin Media: Super Hun 2ac VMDG49 which it looks like its a Netgear modem router
in full modem mode 1.03
I did another wipe of my NighthawkNighthawk X6 R8000
turned on ip6 on 6to4 as before
made sure traffic monitoring was off
Firmware Version
V1.0.4.84_10.1.84
Trevsweb
Jun 15, 2022Tutor
New issue: just added back all my attached reserved IP devices. Doesn't look like the devices are following the reservations. Even the mesh routers and Netgear ap are ignoring the r8000s list.
Weird.
Weird.
- DexterJBJul 11, 2022NETGEAR Moderator
Hi @Trevsweb, are you still experiencing the issue with your R8000?
Dexter
NETGEAR Team
- uksuJul 11, 2022Tutor
Longest know bugs in history of hardware. And these are main functions of a router.
- FURRYe38Jul 12, 2022Guru - Experienced User
Are you using the default IP address range?
You might set a new default IP address range. I use 192.168.1.100 thru .200. Gives plenty of room for reservations and room on either side of the range for static IP set devices.
What all do you have connected to the router?
Mesh and APs? What models?
Weird.
