Apr 01, 2022Guru - Experienced User
New - R8000 Firmware Version 1.0.4.84 Released
Security Fixes: 3/30/22
Fixes security vulnerabilities. (Don't know if this resolves the DNS issues seen on v.76 version.)
For more information about security vulnerabilities, visit https://www.n...
Trevsweb
Oct 09, 2022Tutor
Still outstanding issue about DNS tried everything above and nothing is fixing this temperamental firmware.
I'm assuming by the fact that its a known issue and has been several months that Netgear has dropped support on this device and this firmware is trash.
doing workarounds for ip6 etc did not work for me. I have a personal website that I can't access half the time (before you mention via a vpn or mobile it works flawlessly) this is 100% the routers issue. this firmware should be recalled.
almost on the verge of flashing the firmware to tomato to be done with this.
Certainly has given me less respect for Netgear products.
- FURRYe38Oct 09, 2022Guru - Experienced User
Did you configure IPv6 for Auto Detect?
I hadn't seen any DNS issues after enabling IPv6...
- bitwaveOct 09, 2022Guide
Be careful with Tomato I tried it and bricked my router after recovering from that and doing more research on Tomato and Openwrt they appear to have stopped development some time ago. I'm now running DD-WRT latest build 10-03-2022-r50313 with little headaches. I've been running solid for the past 3 days without a hickup. I do have 1 of the 5Ghz radio's that is problematic while the other 5Ghz and 2.4Ghz are working perfectly for me. At least its usable now.
đ
- DMP11400Oct 09, 2022Tutor
I can't believe that there are still issues outstanding with this router. I will never buy another Netgear product. I rolled back my firmware to a version that works and have been watching the progress of other folks with issues. There hasn't been much, but a lot of folks have struggled.
It's been over a year since the DNS issues appeared and Netgear has not fixed a problem they have caused and on top of it all make you pay for help for a problem they caused. Did I read that support is ending for this router? Ending, you've got to be kidding. I wrote to an officer of this company inquiring why the lack of support for this router when folks were having problems. You know what I got back????? Nothing. What a surprise. This was just an awful experience with a company of this longevity and a company of this size...just disgraceful.
