Jul 03, 2024Guru - Experienced User
New - R8000 Firmware Version 1.0.4.88 Released - Hot Fix
Security Fixes: 06/03/2024
This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security
Download Link:...
Sep 20, 2024Guru - Experienced User
DLQ
Sep 20, 2024Aspirant
No, I haven't done a factory reset and reconfiguration. Is that the best option when applying these patches?
- FURRYe38Sep 20, 2024Guru - Experienced User
Only if one runs in to problems that can' be solved by other means. Kind of last resort.
I plan on loading my R8000 up and checking this out.
So far I've been able to change a device name. Router was loaded with v.76 and had been factory reset prior so when I connected it, I had to complete the setup wizard. I only had one device connected, a ethernet connected PC. Set a IP address reservation and then changed the name. MS Edge in Windows 11 Pro x64.
I applied the v.88 FW and allowed it to be processed. After it was completed, I change the PC name again and applied the change successfully. No special characters or spaces used in the device name. Only a one dash (-).
Hoping yours will work after the reset.
- FURRYe38Oct 16, 2024Guru - Experienced User
New FW available:
Enjoy.
