Oct 16, 2024Guru - Experienced User
New - R8000 Firmware Version 1.0.5.88 Released
Security Fixes:
This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security
Security Advisory for Post-Au...
robdog1977
Feb 03, 2025Tutor
I'm already running firmware 1.0.5.88 which is the latest but the download link I received from Netgear had me download V1.0.12.106 which looks like it's intended for an R7000. Should I try to install the firmware suggested to me by Netgear even though it says it's for an R7000?
Feb 03, 2025Guru - Experienced User
v.88 is most current for the R8000. Had you had a R7000 any any point in history?
- robdog1977Feb 03, 2025Tutor
No. Here's a copy of part of the email I received:
Hi Ross,
NETGEAR strongly recommends that you update to the latest firmware version for your R8000 as soon as possible.
A Firmware update was released on Oct. 15, 2024, that addresses security vulnerabilities, however your R8000 has not been automatically updated and is running a firmware version earlier than 1.0.5.88.
OK, Thanks. When I get on Netgears site it tells me my router is at it's "End of Life" and the firmware I'm running is the newest one listed.
