Aug 13, 2022Guru - Experienced User
New - R8500 Firmware Version 1.0.2.160 Released - EOL
Security Fixes: 08/05/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/
Enable IPv6 Auto if you con...
CogX
Aug 13, 2022Aspirant
Anyone install V1.0.2.160_1.0.107 yet, I don't suppose it fixed the DNS probe bug?
Just loaded v.160 on my R8500 thats now connected to my CM1200 cable modem. Factory reset and setup from scratch.
Will monitor for DNS issues. IPv6 is NOT enabled currently.
Speeds are good though:
Default settings, No Armor, Circle or Traffic Meter enabled:
RAXE500 in wireless bridge mode connected to the R8500. 2100Mpbs Connection rate between the two:
- FURRYe38Aug 17, 2022Guru - Experienced User
Well, I haven't seen any DNS issues since first day of loading v.160 on my R8500. I did see some on my wired PC, however I believe a reboot of the PC resolved that as since then, I have not seen any DNS issues on web pages. I had noticed that before I left a bunch of tabs open in Opera. Closing Opera and coming back that first day, and reopening Opera some of the tabs were trying to refresh there pages and some tabs saw the DNS Prob message. However since the reboot of the PC which cleared the DNS caches. Closing and reopening the browser at various times hasn't reproduced any DNS Prob or Proxy messages since. IPv6 IS disabled. I had manually loaded the FW and factory reset and setup from scratch.
I've since turned OFF the wifi radios and installed a Orbi 9 series in AP mode behind the R8500. Working well at this time.
- DanKI6XAug 19, 2022Tutor
Still an issue with the R8500 and the latest .160 firmware. I have to go back to .144 again (year old).
Dan
- FURRYe38Aug 19, 2022Guru - Experienced User
Ya I saw some DNS items yesterday. Still not sure if it was browser cache or something else.
Have you factory reset and setup from scratch?Have you enabled IPv6 on the router as well?
Dan
