Aug 13, 2022Guru - Experienced User
New - R8500 Firmware Version 1.0.2.160 Released - EOL
Security Fixes: 08/05/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/
Enable IPv6 Auto if you con...
Sep 08, 2022Guru - Experienced User
Kind of hard to help out or get a better idea of your environment if you don't give feedback to the questions presented.
I guess all this is no longer important as you have something else replacing the R8500.
Good Luck.
CogX
Sep 10, 2022Aspirant
The not so funny thing is that there are multiple different threads for multiple different Netgear models, but we all have the same DNS error issues, but there's no easy way for us to collectively try to work through any of this, across all models, to maybe see if there is some "ah ha" solution beyond just wishful thinking that the Netgear programmers will some day figure this all out - you know, that they haven't been able to figure out in the past 18 months.
My R8500 did the same thing, after upgrading to the current firmware, finally relenting to enable IPv6, saw the DNS errors go away, but then the router started crashing. I was about to order a new Asus brand router, but then change my mind as now I think I'm going to go the build-your-own router router, so in the meantime I disabled IPv6 and so far my R8500 has stayed up since. But then of course the DNS errors came back. In the scheme of lesser evils, having the periodic DNS errors is better than having one's entire home network crap out for 5 minutes at a time as the router reboots.
