Aug 02, 2022Guru - Experienced User
New - R9000 Firmware Version 1.0.5.42 Released
Security Fixes: 08/01/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
Download Link:
https:...
Jakb
Aug 17, 2022Tutor
Caution:
Updated my R9000 to V1.0.5.42 and now WIFI is non-functional.
Connection lights are off, Wifi button is illuminated, Wireless OFF in control, No wifi signal.
Pressing (and holding) physical button provides no results.
Reset multiple times and re-installed firmware
- FURRYe38Aug 17, 2022Guru - Experienced User
Did you power OFF the router for 1 minute after pressing the reset button for 10 seconds then release?
- JakbAug 17, 2022Tutor
Physical Button will turn on and off blue LEDs and will disable wireless enablement in the website.
2.4, 5 and 60GHz show as enabled in wireless settings
After a while 60GHz signal light turns on, but 2.4 and 5 stay off and no signal found
Factory Reset from website: no changes.
10 second reset button with 1 min off: no changes
Was working just fine this morning and the last while.- FURRYe38Aug 17, 2022Guru - Experienced User
What does the basic tab say for Wireless in web browser.
Try downgrading the FW to prior working version?
