Aug 02, 2022Guru - Experienced User
New - R9000 Firmware Version 1.0.5.42 Released
Security Fixes: 08/01/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
Download Link:
https:...
Aug 17, 2022Guru - Experienced User
Did you power OFF the router for 1 minute after pressing the reset button for 10 seconds then release?
Jakb
Aug 17, 2022Tutor
Physical Button will turn on and off blue LEDs and will disable wireless enablement in the website.
2.4, 5 and 60GHz show as enabled in wireless settings
After a while 60GHz signal light turns on, but 2.4 and 5 stay off and no signal found
Factory Reset from website: no changes.
10 second reset button with 1 min off: no changes
Was working just fine this morning and the last while.
- FURRYe38Aug 17, 2022Guru - Experienced User
What does the basic tab say for Wireless in web browser.
Try downgrading the FW to prior working version?- JakbAug 17, 2022Tutor
It just said "WARNING: OFF" with a big yellow icon
Tempuratures for 2G and 5G weren't even showing up on http://[router_ip]/debug.htm
Rollback to 1.0.5.4 or 1.0.5.4 didn't fix it
I had to backload an old 1.0.4 firmware, enable telnet and then run these commands to get it to work
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R9000-AD7200-x10-Firmware-Ver-1-0-5-24-kills-WiFi/m-p/2086350/highlight/true#M189250
Once it rebooted it worked right away.
Updated to V1.0.5.42 and seems to be running fine.
It might not even have been this software upgrade per se, but it tipped it over the edge.- FURRYe38Aug 17, 2022Guru - Experienced User
So is temp features now seen on the debug page?
Strange that you had to run those telnet commands. A factory reset should have kicked the radios back ON.
Maybe your unit was in some odd state. Others have not reported seeing this issue to date.You might try a factory reset 1st things BEFORE loading next FW update. Just ensure the radios and configuration are clear, then load new FW.
Hopefully this won't happen again.
