Aug 02, 2022Guru - Experienced User
New - R9000 Firmware Version 1.0.5.42 Released
Security Fixes: 08/01/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
Download Link:
https:...
Nov 28, 2022Guru - Experienced User
Did you factory reset the router after the FW was updated and setup from scratch?
RParadowski wrote:
Readyshare not working. Errors = "can't find server" , No USB drive, The Readyshare access does not respond. I've removed the USB drives and the are access able from desktop USB connection.. Power to USB drives indicated be warmth. This post FIRMWARE v1.0.5.42 update. The "Readyshare" no longer appears in Wnidows 10 Network list.
thx,
bob
RParadowski
Nov 28, 2022Aspirant
Thanks for your response. I have not performed a Factory Reset and setup from scratch. I have not done this in the past and generally do not perform factory resets on my phone, computers or watch unless there is a catastrophic failure. If downgrading the firmware does not work, I will look for another solution. Bob.
- FURRYe38Nov 28, 2022Guru - Experienced User
A factory reset would be needed ON the router if problems are seen. This is a long and valid standing troubleshooting step in helping to narrow down problems seen.
Good Luck.
