Dhananjay_1990
Nov 25, 2022Aspirant
new configuration netgear wifi AC2000
Hi Sir, Please tell the "How to configure the Netgear AC2000".
microchip8
Nov 25, 2022Master
Which router model? AC2000 is a speed number, not model
Usually you can go with a browser to http://routerlogin.net or http://192.168.1.1 and configure the device.
- Dhananjay_1990Nov 26, 2022Aspirant
model number:- R6850 DUAL BRAND WIFI ROUTER AC2000
- michaelkenwardNov 26, 2022Guru - Experienced User
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Begin with the Quick Start/Installation Guide.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.What modem/gateway/Optical Network Terminator (ONT) sits in front of your router?
