jaroldk34
May 08, 2021Aspirant
New Dynamic IP Randomly Assigned
Hello! I have been have some network issues. I have got the R6230 Router from Netgear, and it has been working flawlessly, and when I went to log on 3 days ago, it got very slow, so I gave it a couple days and it was still acting up and be exteremely slow. So I decided to check my router panel to see if anything was changed or something causing me to slow dowm, and I saw that my IP Address was randomly changed. The starting of my Public IP Address was "72.", and it is now "98.", does anyone know how to help? I have been dealing with this and I have virtual leanring that I have, and cannont attend because my speeds are becoming very slow. I have stuck with the same IP for a long time, and now changes. Does anyone know how to know if anyone else is using the IP Address, so that I know that it is still avaliabe for me to forward my router to the IP, and if you know how, please help!
> [...] I have got the R6230 Router [...]
Firmware version? Connected to what?
> [...] The starting of my Public IP Address was "72.", and it is now
> "98.", [...]Another octet ("72.xx." and "98.yy.") might help (a little) to
interpret those numbers.What led you to believe that a different public (WAN/Internet) IP
address was a problem?> [...] I have stuck with the same IP for a long time, and now changes.
> [...]The "D" in DHCP stands for "Dynamic". That address is determined by
your ISP.> [...] Does anyone know how to know if anyone else is using the IP
> Address, [...]
The probability of your ISP giving out a bad address is, I'd
estimate, vanishingly small.> [...] acting up and be exteremely slow. [...]
Not a very detailed description of anything.
Forget your IP address. Concentrate on actual symptoms. Why blame
the router, instead of, say, your (unspecified) modem?- jaroldk34Aspirant
Sorry for not specifying my modem! I have the Touchstone SB6183, connected to my R6230 Router. My specified IP's, my old IP started off with 72.207, and now my new IP starts off with 98.164. I blamed the IP because before I was transfered to the new IP, I was sat on channel 1, seemingly the best channel for my area, and when I was changed, I was getting very poor speeds, going as low as 5 mbps download, with 0.2 upload. Also, I tried all of the channels for the new 2.4gHz IP, and they all perform the same, but with channel 11 showing a little better performance in speeds. Only reason why I would go for the router, and not the modem is because the router will sometimes, but rarely, just stop connecting to internet, so I thought it would be a similar problem with the router, just very low speeds. (I am on V1.1.0.106_1.0.1 for my firmware version, seemingly the newest firmware.)
> [...] SB6183 [...]
Only a modem (not a modem+router), so it should be harmless, but
that's not a guarantee of trouble-freedom. What happens if you connect
a computer directly to the modem? Or, point a web browser at
192.168.100.1, and ask it how it's doing.> [...] 72.207, [...] 98.164. [...]
So, Cox and Cox? Not very suspicious, but if they changed something
on their end, many things are possible.> [...] I was getting very poor speeds, [...]
Wired or wireless?
> V1.1.0.106_1.0.1 [...]
Recent change?
> [...] Only reason why I would go for the router, and not the modem is
> [...]Speculate less, test more?
Problems with Netgear router firmware are frequent enough, but there
are other possibilities.
