michaelkenward
Sep 13, 2021Guru - Experienced User
New fiirmware for R7800
The Windows desktop Genie tells me that there is new firmware for the R7800. Going from 1.0.2.82 to 1.0.2.84.
This firmware has not landed on the support pages for the R7800.
Nighthawk X4...
Enhancements:
- Ookla speedtest optimazation.
Security Fixes:
- Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security.
Download Link: https://www.downloads.netgear.com/files/GDC/R7800/R7800-V1.0.2.84.zip
Firmware Update Instructions:
To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit https://www.netgear.com/support/product/R7800.aspx#docs.
- michaelkenwardSep 13, 2021Guru - Experienced User
Netgear has posted the file since I checked earlier today.
It is rare for new firmware to land on the update server before the support pages, but it has happened in the past.
FURRYe38 wrote:
Enhancements:
Oh dear. Someone at Netgear needs to dig out their spiel chequer.
- FURRYe38Sep 13, 2021Guru - Experienced User
Ya I've seen FW upate notifications prior to hitting the on site web pages before. Specially for Orbi systems.
Nah, thats how it's spelt nowadays. LOL.
Ok so loaded my R7800 today to v84. Up from v60 which I had loaded as I was troubleshooting Bridge mode, found the problem there.
I did a full on factory reset and setup from scratch.
1. Still seeing the following happen when going thru the setup wizard and when you select NEXT, the information given is being either changed visually or is being changed from what was actually input by the user:
The Answers seen here are NOT what the user input. Is this expected behavior? DarrenM
2. I see after I let the wizard enabled auto updates, there was a GUI update seen as well:
3. Remote Mangement has been changed to:
Need to find out if this is all thats available and you have to manage the router from the NH app from now on or if there is something missing here. :smileyfrustrated: DarrenM
4. Speed test is fixed. Thank you NG. QoS not enabled.
R7800 Wireless Bridge mode speed results connected to a Orbi AX 853 system in AP Mode:
Im leaving mine in Bridge mode so I can test this out with a different router. Will be connecting my xbox to the R7800. :smileywink:
Over all, there seems to be hope with v84.
Anyone else? Please post your experiences.
