michaelkenward
Jan 14, 2022Guru - Experienced User
New firmware for the R7800 - v1.0.2.90
This just in:
R7800 Firmware Version 1.0.2.90 | Answer | NETGEAR Support
Enhancements:
Remove Funjsq for PR SKU.
Whatever that means.
Lanman175
Jan 17, 2022Aspirant
It appears to be related to qos - Still looking. At first I thought it was related to Java Script.
Areyouben
Feb 05, 2022Aspirant
Is anyone else encountering problems with the 5G Wifi on the latest firmware version 1.0.2.90? Today I’ve tried for the second time to upgrade from .84. This time I’ve tried .90, few months ago I tried .86. Both .86 and .90 result in a very unreliable connection with my Netgear Extender EX7500. The connection between the two is great on firmware .84, around 650Mbps and green bows. On .86 and .90 it gets 48Mbps and red bows. It’s frustrating me not to know what this causes. It seemed to work for a short wile on the DFS channel 128, but radar channels always force the router to use non-DFS channels (also on firmware .84 and below). There hasn’t been an update for the EX7500 for a while, probably it needs one to deal with the R7800’s new firmware?
- FURRYe38Feb 05, 2022Guru - Experienced User
Does the R7800 works with out the EX7500 being online?
What is the distance between the 7800 and EX extender?
- AreyoubenFeb 06, 2022Aspirant
Yeah, the R7800 works, is online and speedtests give the same result as they did under firmware version .84. I gave the EX7500 a few factory resets. It didn't want to talk with the R7800 with WPS, but eventually a manual setup did the trick. They are now back to their old selves with a steady connection between 585-650Mbps. They're about 15 feet apart. The extender is hanging just around the corner in my hallway, so the only thing in between is a concrete wall / cardboard filled door, depending on how the signal travels.
- FURRYe38Feb 06, 2022Guru - Experienced User
Well 15 feet maybe too close and 30 feet would be a starting point. However with concrete in the mix, maybe something thats causing problems.
Might try the extender maybe 5-10 feet farther away if you can...
