Franardo316
Jul 26, 2021Aspirant
New Firmware upgrade R7000
I applied the new firmware upgrade and noticed a decline in speed in upload and download , is this normal. Will there be a fix?
Jul 26, 2021Guru - Experienced User
Which firmware did you upgrade to?
Did you do a factory reset/reinstall after the update?
What speeds were you getting? And now?
Are thos speeds over 2.4gh? 5gh? wired?
How are you testing speeds? (device, website, app, etc)
Franardo316
I using the net gear app gor the speed and 5ghz connection, called isp and there’s no issue on their part
