thephilnewman
Jul 12, 2022Tutor
New internet provider using existing netgear router
I have just changed internet service providers and I want to use my existing router but don’t know how to set it up
- Jul 12, 2022
Jul 12, 2022Guru - Experienced User
What model router do you have?
This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/24104/How-do-I-change-my-Nighthawk-router-to-AP-mode-after-I-ve-already-run-setup
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
Try option #2 first...
- thephilnewmanJul 12, 2022Tutor
Hello, My existing router is a Net gear Nighthawk AC1900, My new supplier has fitted me with a TP Link AX1500 WiFi 6 Router, the problem is i have an extender so i want to use my Net gear Nighthawk router. My Extender is a Net gear AC2200
- FURRYe38Jul 12, 2022Guru - Experienced User
Those AC numbers are wifi combined numbers.
The NH router will be a R#### and extender should be a EX####.
What is the brand and model# of the ISP modem/ONT that the TPlink is connected too?
Router is R7000
Extender is EX7700
New router that i have been supplied with is a TP Link Archer AX10
