Conflict's avatar
Conflict
Initiate
Dec 03, 2019
New ISP Spectrum. Internet speed is halved using router.
Modem: Arris Surfboard 6183
Router: NetGear R6400V2 (V1.0.4.84_10.0.58)
QOS, Traffic Meter, SmartConnect disabled.
Recently just moved and bought the Spectrum 400Mbits plan. After hooking up my router, my speed tests always range from 170~230Mbits. All the PCs (wired) and Phones get that speed. Decided to do a straight wire to my PC and was getting the 400Mbits range. Tried different ethernet cables from Modem to Router, issue persists. Tried a hard reset on router. Speeds are basically halved.
Is there a solution to fixing this issue? Could not find any. Thank you.
  • Issue solved.
    Downgraded to firmware V1.0.3.66_10.0.50 gave me back all the speed.
    Any firmware version above this will bring my speeds back down to 200Mbits range.
1 Reply
  • Issue solved.
