nepotize's avatar
nepotize
new netgear,, want to set as a bridge to old,
hi all    My old router only submits wifi,, No ethernet.  New netgear nighthawk D7000V2 out of the box needs to be configured as the bridge, Can i logon to the D7000v2 and configure it with out hoo...
  • schumaku's avatar
    Jul 05, 2021
    nepotize wrote:
     My old router only submits wifi,, No ethernet.  New netgear nighthawk D7000V2 out of the box needs to be configured as the bridge, Can i logon to the D7000v2 and configure it with out hooking it up to the internet.
    In my understanding the D7000v2 does require a wired connection - being either an xDSL link to the ISP or an Ethernet connection to whatever device is providing the uplink, e.g. the Internet access.
    In the second case, with an Ethernet link to an upstream router, you can configure the D7000v2, you can Nighthawk AC1900 WiFi VDSL/ADSL Modem Router Model D7000v2 - Use the Modem Router as a WiFi Access Point (p.91 ff.).
    If your only connection towards that other router is wireless, there is nothing you can do with the very sophisticated D7000v2 (a modem-router device). For this use case, a WiFi Range Extenders are the way to go.
