joeycastiglia
Nov 06, 2021Aspirant
New NIGHTHAWK XR300 Not working while white lights are on and connected
I just opened my router and connected it to my modem. Everything was working fine. I connected to the installation assistant website as displayed in the guide. I finished the prompts on the website a...
- Nov 07, 2021I did a complete factory reset and went through the installation assistant again and this worked
joeycastiglia
Nov 07, 2021Aspirant
I can “connect” to the router. I get the indication on my computer that i am connected to the router. However when I try to access the internet in any way I cannot load anything. I did check out some other forums and haven’t found anything yet. Thank you for directing me to the other one.
Nov 07, 2021Guru - Experienced User
- joeycastigliaNov 07, 2021AspirantIt’s an Arris modem and the Model No is - TM1602A
- FURRYe38Nov 07, 2021Guru - Experienced User
While the XR router is ON, Power OFF the ISP modem for 1 minute then back ON.
- joeycastigliaNov 07, 2021AspirantJust did this, nothings seem to changed
