neuroscienceyog
May 07, 2020Tutor
New R6900P connected to everything but Brother MFC-7860DW wirelessly
Successful install on new R6900P MU-MIMO which is connected to three laptops, 2 phones, TV, etc. working flawlessly in both 3 and 5 modes. However, cannot connect to Brother MFC-7860DW wirelessly w...
- May 15, 2020
You said to contact the manufacturer, which is what I did. Brother has an excellent presentation by one of their folk for this printer which has many views. Fortunately, they also have a lot of discussion on some of the important points, three of which were critical in making a successful connection.
Thanks for your time.
May 07, 2020Guru - Experienced User
did you use the same ssid from the old router to the new?
or is it a new ssid?
Reason I ask, is with some older devices, they don't play well with smart connect.
Sometimes you need to disabled smart connection with the 2.4ghz band set as the same ssid as it'd be with smart connect running and the 5ghz ssids changed. Then you get the device setup and turn the smart connect back on.
Are you using smart connect?
are you trying to set it up via wps? or how are you trying to connect it?
- neuroscienceyogMay 07, 2020Tutor
Tks for the reply. No, the ssid has changed with the new router. Am not familiar with "Smart Connect". The printer has been connected with only wirelessly and relatively seamlessly with a few quirks for several years.
Running with new router, we're getting the full 100 Mbps from Comcast on 5 ghz. Envision it would be with 2.4 ghz given the printer limitation as wouldn't expect it could handle 5 ghz. Given COVID 19 and the the huge demand for network capacity everywhere, am running 2.4ghz unless we're watching a movie. Seems like Comcast watches daily usage carefully and runs some kind of allocation algorithm.
- plemansMay 07, 2020Guru - Experienced User
neuroscienceyog wrote:Tks for the reply. No, the ssid has changed with the new router. Am not familiar with "Smart Connect". The printer has been connected with only wirelessly and relatively seamlessly with a few quirks for several years.
1. I don't think comcast is running any allocation programs. I've got gigabit and once everything was setup properly, I can routinely hit gigabit whenever I test/stress it. They do run data caps but have relaxed it during the covid issues.
2. You still didn't say how you were trying to setup the printer. Using a pin method, using wps, using som other method from the manufacturer.
3. Did you try contacting the manufacturer of the printer to see how they'd recommend connecting it?
- neuroscienceyogMay 15, 2020Tutor
