ng_husker
Jan 24, 2021Guide
New R7000 firmware 1.0.11.116 failure to update
Just found the latest firmware updated here: https://www.netgear.com/support/product/r7000.aspx#download Unzipped the download, and tried to update the firmware *.chk file using the Upload butto...
- Mar 04, 2021
Netgear must have updated the 1.0.11.116 download, because this week I tried again, and this time it installed successfully. Not sure what the issue is, but clearly Netgear updated the patch. Darn I wish I had kept the old download, could've checked sized and diffed it against the new one.
ng_husker
Jan 25, 2021Guide
Yep as in my OP: Model: R7000|AC1900 Smart WIFI Router
Version: V1.0.11.106_10.2.100
Thx.
ng_husker
Mar 04, 2021Guide
- antinodeMar 04, 2021Guru
> Netgear must have updated the 1.0.11.116 download, [...]
> [...] clearly Netgear updated the patch. [...]
I believe that you meant to say, "I wonder if Netgear [...]".
> [...] I wish I had kept the old download [...]
Not everyone is so careless.$ pwd /Software Kits/Netgear/R7000 $ ls -l R7000-V1.0.11.116_10.2.100.zip -rw-r--r--@ 1 sms staff 31011144 Jan 21 13:15 R7000-V1.0.11.116_10.2.100.zip $ ls -l ~/Desktop/R7000-V1.0.11.116_10.2.100.zip -rw-rw-rw-@ 1 sms staff 31011144 Mar 4 13:37 /Users/sms/Desktop/R7000-V1.0.11.116_10.2.100.zip $ diff -s R7000-V1.0.11.116_10.2.100.zip \ ~/Desktop/R7000-V1.0.11.116_10.2.100.zip Files R7000-V1.0.11.116_10.2.100.zip and /Users/sms/Desktop/R7000-V1.0.11.116_10.2.100.zip are identical $ unzip -l R7000-V1.0.11.116_10.2.100.zip Archive: R7000-V1.0.11.116_10.2.100.zip Length Date Time Name --------- ---------- ----- ---- 31010874 01-17-2021 23:05 R7000-V1.0.11.116_10.2.100.chk 1143 01-17-2021 23:13 R7000-V1.0.11.116_10.2.100_Release_Notes.html --------- ------- 31012017 2 filesWhat's your next hypothesis? Mine is that you made some kind of
error on your first attempt.- ng_huskerMar 04, 2021Guide
First time: browsed to firmware update file, and click ok. When it gets the error message, redownload, rinse, and repeat.
Second time: browse to firmware, and click ok. Works, no error message.
You offered zero helpful information on original post. But thanks for being a d##k. Please call our hotline at 1-800-GFY-ASAP.
> First time: [...]
> Second time: [...]
It's nice that you're happy with what you claim that you did, but the
non-psychics in your audience have no way to verify what you actually
did with which file(s).> You offered zero helpful information on original post. [...]
Unlike your latest content-free I-did-everything-correctly post?
What _I_ did was demonstrate that the R7000-V1.0.11.116_10.2.100.zip
kit which I fetched today is identical with the one which I fetched
on/at "Jan 21 13:15" (US-CST). Which suggests that your "Netgear must
have updated" and "clearly Netgear updated" claims are about as valuable
as the rest of your content-free problem description.
That actual information, based on facts rather than (faulty)
speculation, might not be "helpful" to _you_, but it might save some
other poor fellow from chasing a nonexistent problem with the original
R7000-V1.0.11.116_10.2.100.zip kit.But thanks for your thoughtful and constructive criticism.
